- Thank you received: 323
- Forum
- Wheel Horse
- Wheel Horse
- Restorations + Mods
- How To Make An 18 Automatic Into A 23 Automatique LSE
05 May 2017 22:57 #91
you doing a great job..................
- 23 AUTOMATIC LSE
- Thank you received: 26
07 May 2017 00:56 - 07 May 2017 00:59 #92
by 23 AUTOMATIC LSE
Hydro Motor to Transaxle / Transaxle to Frame
177.) Transaxle motor gasket area taped off
178.) Tape removed/cleaned
179.) Comparing different gaskets, notice the second one would leak!!!
180.) Strainer
181.) Installed
182.) Gasket placed on transaxle with guide bolt
183.) Hex bolts/washers
184.) Motor installed
185.) "I.D." Tag
186.) Installed
187.) Transaxle mounted to frame with Dipstick and Chrome oil fill nipple
188.) Hex bolts/washers
180.) Strainer
181.) Installed
185.) "I.D." Tag
186.) Installed
Last edit: 07 May 2017 00:59 by 23 AUTOMATIC LSE.
07 May 2017 09:41 #93
Wow, super nice, and finally on the frame woot.
- Thank you received: 137
07 May 2017 20:53 #94
Replied by Trouty56 on topic How To Make An 18 Automatic Into A 23 Automatique LSE
I have never seen anything like this....a complete tear down..... you have to a very patient person.....
- 23 AUTOMATIC LSE
07 May 2017 22:08 - 07 May 2017 22:43 #95
by 23 AUTOMATIC LSE
Thanks Bob, I know what you mean; but, when it's something you enjoy doing it doesn't seem so bad.
I just want to interject in here that when I did the spindles on the front axle, I had to use an old thrust bearing {with missing needles} because I could not find my other new one. I was looking around for something else and I found it, so now I have both new thrust bearings on.
Last edit: 07 May 2017 22:43 by 23 AUTOMATIC LSE.
11 May 2017 07:36 #96
Super job!!!.
- 23 AUTOMATIC LSE
11 May 2017 21:10 #97
by 23 AUTOMATIC LSE
Had a go at mocking up a couple of the Ag's on the rear, yes I know the tread is the wrong direction. Didn't catch it till after I already had them on. The models that are equipped with a hydro cooling fan, have the mounting bracket sandwiched between the frame and a couple of the transaxle bolts. I temporarily mounted this for a photo op, but will remove and reassemble it later so it doesn't get too bumped around. I am currently trying to source some Woodruff keys {Part# 907346} for the 4 hubs.
- 23 AUTOMATIC LSE
13 May 2017 18:29 #98
by 23 AUTOMATIC LSE
Just a little update on my progress, as you may have noticed one of the rear tires does not hold air. This is not due to the tire rather the wheel assembly, specifically, the area where the valve stem hole was welded shut and ground down. It was taken down too far and this is where the air leaks, so needless to say it's going to have to be rewelded. I still have to get the other two tires mounted and test them for leaks. In the meantime, I assembled the side panels to the frame.
13 May 2017 22:11 #99
That's coming along very very nice.............when you think you will have it all together?
I hope soon cause that will be a winner for sure..
- 23 AUTOMATIC LSE
14 May 2017 15:20 #100
by 23 AUTOMATIC LSE
Nappy, I don't have a target date. I do have a lot of parts redone, but they are for later on in the reassembly. I have to reassemble each one in order, some I don't even have yet. Next is the rear wheels/tires which requires the 4 Woodruff keys for the axles. The local Fastenal moved so I may try to find another close, to purchase from. I also need to finish the discs for the brakes...
- Forum
- Wheel Horse
- Wheel Horse
