How To Make An 18 Automatic Into A 23 Automatique LSE - Page 11 - WHS Forum
15 May 2017 16:06 #101 by 23 AUTOMATIC LSE
Here's a sneak peek at the decal on the hood.
16 May 2017 05:26 #102 by nappypappy
good idea and I still have mine for my 1985...................:agree
16 May 2017 08:02 #103 by Geno
Wow you are moving right along Mark, looks awesome woot. :10
17 May 2017 16:45 #104 by 23 AUTOMATIC LSE
Thanks, Geno I have some Woodruff keys on order I am supposed to get a call to let me know they are ready for pick-up may be a week, though. I have to get the one tire that leaks, unmounted to get it rewelded and refinished then remount it, I also have to mount the other two ags to the other two wheels. Can't wait!
27 May 2017 13:54 - 27 May 2017 13:56 #105 by 23 AUTOMATIC LSE
Woodruff keys arrived, ordered 8 so I now have an extra set. These appear to be the same as the ones for the 953, 1054(A) GT-14 and 18 Automatics. I am hoping to get the 2 hubs that I will be using on the outside off of the axles that they are currently on. Thinking of having a go at soaking in some Acetone/ATF 50-50 mix, for a while, then having neighbor press them out. Will have to wait and see.
28 May 2017 18:23 #106 by Geno
One more thing conquered. :thumb1
02 Jun 2017 20:11 #107 by 23 AUTOMATIC LSE
Just a bit of an update, as I am currently awaiting some rear wheel weld repair and tire mounting, I decided to skip past steps 189 through 213 and proceed to assemble some parts to the frame.
214.) Steering column support Assembly
215.) Hex Bolts
216.) Nyloc Nuts
217.) Installed on frame
218.) Ross steering column
219.) Worm gear housing
220.) Upper ball bearing race
221.) Upper ball bearings/keeper
222.) Shaft
223.) Lower ball bearings/keeper
224.) Lower ball bearing race
225.) Spring Washer
226.) Adjusting plug
227.) Retainer
228.) Seal
229.) Installed
230.) Stud
231.) Lever
232.) Stud nut
233.) Installed
234.) Washer
235.) Installed
236.) Hex nut installed
237.) Lock nut
238.) Lock nut installed
02 Jun 2017 20:34 - 02 Jun 2017 20:42 #108 by 23 AUTOMATIC LSE
The manual does not include the hex bolts that secure the column to the support assembly, nor does it give part #'s for these 3 bolts.
239.) Hex bolts
240.) Mounted on support
241.) Hex bolts installed
242.) Upper steering column bearing {These last 2 pics were inadvertently left out of the previous post.}
243.) Installed
03 Jun 2017 09:16 - 03 Jun 2017 09:22 #109 by 23 AUTOMATIC LSE
Drag Link:
244.) Drag link end {Non O.E.M.}
245.) Drag link
246.) Drag link end Installed on Drag link
247.) Drag link end on bell crank
248.) Drag link attached to drag link end on bell crank
249.) Drag link attached to steering lever
03 Jun 2017 11:41 #110 by 23 AUTOMATIC LSE
Neutral Return Pedal:
250.) Parts
251.) Shaft
252.) Right bearing
253.) Inserted in frame
254.) Ditto Left bearing
255.) Shaft installed
256.) "E"-Ring clip
257.) Installed on left end of shaft
258.) Shaft in right side
259.) Spacer
260.) Neutral return pedal
261.) Positioned on shaft with spacer
262.) Roll pin
263.) Positioned in hole
264.) Inserted
265.) Spring / anchor plate / bolt & nut installed
