- Thank you received: 18
Project Clydesdale
- Bert
- Senior Member
28 Jan 2019 19:02 #71
by Bert
Replied by Bert on topic Project Clydesdale
That’s a pretty neat build, looking forward to seeing it finished
28 Jan 2019 20:11 #72
Thanks and good to see you Bert.
28 Jan 2019 20:16 - 28 Jan 2019 20:17 #73
I'm on to a 25HP Kohler Command, just need to get outta here to pick it up.
nappypappy wrote: I still thing you may need a transfer case or maybe a bigger motor like what GT has on his wheelhorse...........
Last edit: 28 Jan 2019 20:17 by Geno.
- Bert
- Senior Member
28 Jan 2019 20:46 #74
by Bert
Thanks, it’s good to be back.Geno wrote: Thanks and good to see you Bert.
30 Jan 2019 18:09 #75
Most of the front brake set up is done. The factory lock system is blasted, painted and in the tractor. I took the rear bracket that was welded on the back of the factory rod off and it will be welded where the vise grips are holding it, then I need to make an extension for the original rod to my new rod so they can link together. The spring is temporary to hold it in the first brake lock notch, the entire travel will only be about 1/2" from released to locked so I want to make sure it's in the lock area. It still has the bottom spring setup off of the original setup so there will be some adjustment.
31 Jan 2019 17:44 #76
A lot going on today but I did manage to finish the front braking setup. Everything from the pedal to the lock setup is original minus the extra rod tab, and the adjustment is original just flipped so it gets pushed on instead of pulled on. It works really well, I just had to rebend the rod a little from yesterday.
01 Feb 2019 18:20 #77
The fender is on and notched for the new brake setup. It's not the prettiest but that will be fixed after it's plated lol. I made a new bracket to hold 2 fuse blocks and moved them up a little above the battery top so they're easier to get to. Now to figure out what is next...
02 Feb 2019 12:13 #78
That brake rod is not coming off that's for sure.
05 Feb 2019 21:29 #79
I hope not, like Nappy says, safety first lol.
06 Feb 2019 18:37 #80
Good news is I got out for pizza and to pick up my engine today. It's a Kohler command Pro 25HP.
Bad news is it is in pieces lol. The rings were stuck in it from sitting but everything else looks good minus a good cleaning, rings, gaskets, and reassembly.
