What's everybody doing?
23 Jan 2017 16:07 #211
I could make some serious money doing this one, the book is probably 8 hrs. on this one.
Geno wrote: There are always sneaky ways to do things lol. Mechanics make a lot of money charging book time then finding the little well kept secrets...
23 Jan 2017 16:48 #212
I could buy a pretty nice Wheel Horse with the labor on that job alone lol.
23 Jan 2017 18:17 #213
My job today, install an new alarm system in the shop. The old one that I put in in 97 when I built the shop has a keypad problem that has been giving me fits for years. I never had a problem with the system and it may have lasted another 20 years, but the keypad hasn't been wanting to work for quite awhile. I reused all of the wired sensors that have never given me a problem and am adding some wireless features.
The new system has been integrated with all of the old wired sensors and has a 99 zone wireless system. It calls phones when it goes off, has an app to run it, it even talks and welcomes customers from the door trigger lol. The thing I like the most is it has remotes, no more keypad use unless I feel like it or to set things up in it.
I'll have to get a vid of it when I get all of the extra sirens and strobes installed inside and outside.
- Thank you received: 323
23 Jan 2017 18:34 #214
I'll have to get a vid of it when I get all of the extra sirens and strobes installed inside and outside. [/quote]
Wow I would like to be there when that goes off........but not inside if there's some deadly gas blowing in there....
23 Jan 2017 19:07 #215
Radio Shack used to sell useful gear, now its cell phones and batteries. Don't expect them to be in business much longer.
23 Jan 2017 19:09 #216
Maybe two
Geno wrote: I could buy a pretty nice Wheel Horse with the labor on that job alone lol.
Maybe two
- Thank you received: 73
25 Jan 2017 12:56 #217
I still like the old style burglar alarm, but it requires picking up poop each morning...
25 Jan 2017 14:08 #218
That's the best alarm ever made. If it weren't for the chance of getting sued because my dog ate up someone who broke into my shop I would have one in a minute!
27 Jan 2017 18:16 - 27 Jan 2017 18:18 #219
The extra strobe sirens came in today. I got the inside ones mounted, still have to do the outside. Since the alarm is a 12V based system I'm running the system through my test bench \ sound system and using the battery in there for backup which should run it for about a week lol.
I had all of the inside sirens hooked up and after a minute or so the alarm head unit shut them down, but the internal siren in the head kept working. They came back after a rearm so there must be an overload circuit for protection of the outboard siren circuit. I thought no big deal, I'll let the siren output trigger a 30A relay off of the battery in the test bench and then I can run all the sirens I want. I had the relay hooked up and pushed the panic button on one of the remotes and the relay wouldn't engage... I checked the voltage out of the siren driver and it was only 7V, not enough to trip the relay.
I don't know if running the extra sirens weakened the circuit or if it was always 7 volts. The unit works great with 2 sirens at 7V, but not more than 2. The sirens are rated at 5-12V. I can't get any help from the manufacturer so I called Amazon and asked them what I should do. They said since the unit was installed they would just credit me for this one and I could order another one and use what I needed. This is why I deal with Amazon so much.
Another one will be here Monday. If that one does only 7V out of the siren driver I'll know it's normal I guess, and put that one in the house with just the 1 siren that comes with it or 2 sirens lol. There's also a 10A 6V to 12V step up transformer on the way for the shop just in case.
Last edit: 27 Jan 2017 18:18 by Geno.
27 Jan 2017 21:46 #220
Well you been busy I see and me put new axles and hubs on the front of the jeep...it needed it ....that's what I been doing..
Time to create page: 0.160 seconds
