Tiller guts - WHS Forum
Tiller guts
21 Mar 2015 21:22 - 16 Apr 2016 20:46 #1 by Trouty56
Tiller guts was created by Trouty56
For those who may be looking inside a tiller.....
Looks pretty straight forward.....I needed to put some seals in....takes 2 each side for the main drive and 1 for the input.....
this collar is held in place by a pin....
parts all laid out......
Seals are CR 12330 (4) and CR 7410 (1) I believe.....well pretty sure....at least that is what I have ordered....
It is 4-16-2016 and I am adding something to your post Bob. :)
This tiller is a 07-36TL03, it was built from 1984-1989. The gears in this tiller are factory machine welded and don't come off.
The following user(s) said Thank You: Geno, GT 14, M Bailey, Kyblue, nappypappy, Scott
21 Mar 2015 21:51 #2 by Scott
Replied by Scott on topic Tiller guts
Nice! Thank you for showing these pics. Were building a nice how too list. If the weather stays nice I have a few I would like to ad.
22 Mar 2015 04:47 #3 by GT 14
Good info.
Thanks
22 Mar 2015 05:04 - 22 Mar 2015 05:16 #4 by Trouty56
I have a bearing list also...but these bearings looked in such fine shape I'm not replacing them.....one thing worth mentioning....the main shaft where the pins hold the tine assembly get cratered a little and need ground a bit for the case to come off easily. One tine is broken...gonna try and make one then weld it in place....or maybe purchase a D series tine and weld it on....those can still be bought. Was also thinking about using a mower blade...not sure if they can be torched and bent or not....any ideas on that?
22 Mar 2015 05:25 #5 by GT 14
You might be able to find an old walk behind cheap and get some donor tines.
22 Mar 2015 05:37 #6 by Trouty56
GT 14 wrote: You might be able to find an old walk behind cheap and get some donor tines.
Maybe....dunno......a D series tine costs about 12 bucks.....they might match up pretty good also...probably have to buy 2 though cause I get confused on whether it is a righty or lefty. I've read a couple forums where guys just make them out of 1/4 inch plate too....weld them on with a hard rod and let them sharpen themselves....guess they just heat and bend them little by little to get the shape right.
22 Mar 2015 06:52 #7 by GT 14
If you can get em for 12$ that is the way to go. Even buying left and right you may need the other in the future.
22 Mar 2015 07:48 #8 by Geno
Replied by Geno on topic Tiller guts
Nice Bob. Let us know if the seals work out. :thumb1
22 Mar 2015 07:49 #9 by M Bailey
Replied by M Bailey on topic Tiller guts
Never seen the insides of one before, surprised they are that simple. Thanks Bob!
22 Mar 2015 08:47 #10 by Kyblue
They really are simple ... I'll need to put a chain in mine this winter.
