- Thank you received: 60
Cable sticking (Solved)
- Moderator - Supporter
What can cause this?
How can it be fixed?
So I was able to free up the throttle cable but the choke was still stuck. The tractor ran for about 45 minutes after that then it just died, to never start again.
Im thinking the choke may have been on for that amount of time and possible fouled out the plug or something.
I need your expertise. Please Help..
- Thank you received: 323
If the choke is stuck on my 416-8 it wont run 5 minutes....I no that's not any help for youAJ WH Ranger wrote: Hey guys I need some advice. Last night I was cutting the grass at my new neighbors house and shut off the tractor to say Hi. When I got back to the tractor to start it back up both my choke and throttle cables were frozen.?
- Thank you received: 116
Here is an Update.
I found the problem(s)
First one, both of the cables were seized up weird I know. A WD-40 bath and some coaxing did the trick for those.
Second one, this is the one that bothers me the most and took the longest to figure out. I would imagine it would take anyone a few minutes to troubleshoot their way to this but, the kill switch I had wired up had apparently broke internally therefore shorting it out to ground regardless of switch position. (swear words)
So now I am back to mowing with the 1968 Lawn Ranger with no hood so I have a way to short the plug to ground so I can shut it down.
- Thank you received: 137
That is weird.....sounds like something that would happen to me......Geno wrote: Glad you found it AJ. So it looks like 3 things went pretty much at once? Doesn't get much weirder than that.
