- Thank you received: 116
Routine Maintenance
11 May 2015 10:53 #1
Routine Maintenance was created by M Bailey
Time to service the C-101 today. With 32 hours since last years rebuild on the meter and 25 since the last service it was time to get dirty. Greased the axle, spindles, wheels and steering sector. Checked the trans fluid level and cleaned the air pre-filter and blew out the paper filter. I do not oil the pre-filter as I've found that the oil leeches into the paper filter and shortens its usable life.
Get out the tools for the oil change including the handy little oil trough which makes changing oil with a deck on a snap.
2-1/2 quarts of oil and a new sticker under the hood and the old horse is good for another 25 hours.
Putting the wrench size along with oil capacity on the sticker helps out for next time, especially if you're like me and can't remember what you had for breakfast
11 May 2015 12:11 #2
Replied by Geno on topic Routine Maintenance
The handy little oil trough, what an idea!
11 May 2015 12:51 #3
Replied by GT 14 on topic Routine Maintenance
Good idea Major, always a pain with the deck on.
11 May 2015 16:17 #4
Replied by M Bailey on topic Routine Maintenance
- Moderator - Supporter
- Thank you received: 60
11 May 2015 16:24 #5
Replied by AJ WH Ranger on topic Routine Maintenance
It look like a housing for a small air pump cut in half..
- Thank you received: 323
11 May 2015 16:32 #6
Replied by nappypappy on topic Routine Maintenance
11 May 2015 18:13 #7
Whatever it is I have to have one!
12 May 2015 09:20 #8
Well if you look around your shop you mostly have two or three of whatever...Geno wrote: Whatever it is I have to have one!
12 May 2015 12:05 #9
If I had one of those I'd know it. I thought about just cutting a piece of PVC pipe in half for starters, then I would have 2.
12 May 2015 13:24 #10
Good thinking....twos better than one....Geno wrote: If I had one of those I'd know it. I thought about just cutting a piece of PVC pipe in half for starters, then I would have 2.
