Rj 58 progress - WHS Forum
Rj 58 progress
10 Mar 2015 18:05 #1 by motor12
Rj 58 progress was created by motor12
On Geno's prior Wheel Horse site I had started my RJ58 project and will continue to post updates and pictures on the new site. I know everybody likes pictures. Just a recap of where I am now. The tractor has been taken apart and cleaned. This week the big parts are to be sand blasted and primed, The transmission was locked up and when I tore it apart, I found broken teeth, lots of rust and the trans fluid had solidified .I have since completed the trans rebuild, found replacement gears on E-bay, put in new bearings and new bushings, and seals and gaskets. Today I was able to paint the trans and tomorrow I will put on pulleys and brake band and post some pictures. Here are some before
pictures of the tractor and trans gears.
The following user(s) said Thank You: Geno, Sandra, nappypappy
10 Mar 2015 18:39 #2 by Geno
So glad you brought this over Motor. Don't want to miss this one. :thumb
11 Mar 2015 14:28 - 11 Mar 2015 20:38 #3 by motor12
Finished up the trans and attached a couple pulleys. Here is a before and after picture.
The following user(s) said Thank You: Trouty56, nappypappy
11 Mar 2015 15:09 #4 by nappypappy
Replied by nappypappy on topic Rj 58 progress
wow looks like new now or even better than new.....great job :cool
11 Mar 2015 18:46 #5 by Geno
What a handful, especially the welded on brake pulley. You do some nice work Motor. :goodjob
11 Mar 2015 20:47 #6 by JustinW.73
Replied by JustinW.73 on topic Rj 58 progress
Man I hope my raider turns out half that good. Great job motor. :goo
1973 Automatic 14
11 Mar 2015 22:54 #7 by jm46322
Replied by jm46322 on topic Rj 58 progress
nice work on the trans, It looks like your setting the bar pretty high for the rest of us.
sealing up a rebuild is almost bitter sweet, a LOT more work goes into it then most ever see or know.
when you open them up to find a mess and nothing turns its great being able to run through all the gears and see the wheel shafts turn when your done;
Then that nagging question what were they thinking when that brake got welded?
I know we all hate that feeling when run across those speed bumps.
SPEED BUMP was about the only thing i could think of that describe them that would not get in trouble.
cant wait to follow the progress.
12 Mar 2015 08:13 #8 by M Bailey
Replied by M Bailey on topic Rj 58 progress
Great job Motor. I agree with John, jm46322, about modifications done by previous owners, what the heck were they thinking when they welded the brake drum to the shaft!? At some point a po of my Suburban decided to move the seat back (not a good idea) so they cut out the brace on the top of the tool box which lead to multiple cracks due to lack of support for the fenders. Lots of extra effort to repair in the end.
12 Mar 2015 08:15 #9 by JustinW.73
jm46322 wrote: nice work on the trans, It looks like your setting the bar pretty high for the rest of us.
Setting the bar high? Ya got that right. I think these pictures are going to make me take every bolt, nut, washer, clip, everything and paint all of it. I was just going to paint the frame and trans together. But I don't know if I can do only that now.
1973 Automatic 14
12 Mar 2015 10:05 #10 by motor12
Thanks for the support guys, And you are correct JM46322 when the trans was done and all the gears spun like they should it was a good feeling. :happy1
