- Thank you received: 73
854 back rest project
07 Apr 2018 13:05 - 07 Apr 2018 13:07 #1
854 back rest project was created by motor12
Some say the 854 had a factory back rest, if it didn't so be it. My 854 has one, and this is what i did.
I bought two one foot by three feet pieces of 1/8 in. ash hobby grade plywood. Then cut to a rough 8 in. by 1 foot size and glued four pieces face to face with lots of wood glue. Then clamped the 1/2 in. piece to a curved concert garden border section with every clamp and vice grip I had. Let it dry over night, when I removed the clamps the plywood retained the curve. After making the back rest pattern on paper I traced it onto the plywood and carefully cut out the back piece. Then located the attaching holes , installed the recessed 5/16 in nuts. Finally put two coats of sealer on to water proof the plywood. I don't have the know how or equipment to do the vinyl cover so I took it to my local upholstery guy and he did the covering. The finished back rest has 1 1/2 in of dense foam with a marine grade vinyl. the overall size is 10 in. wide by 7 in. high and 1/2 in plywood with 1 1/2 in. foam. It is comfortable and looks good on the 854.
Last edit: 07 Apr 2018 13:07 by motor12.
- Thank you received: 323
07 Apr 2018 13:22 #2
Replied by nappypappy on topic 854 back rest project
well now that is a mighty fine looking backrest if I may say so.............good job...............................................................
07 Apr 2018 19:38 #3
Replied by Geno on topic 854 back rest project
Expert work as always Motor, very nice.
There was a backrest option for those tractors but they didn't come with it on the tractor, it was an accessory. I have one around here somewhere lol.
08 Apr 2018 08:29 #4
Replied by GT 14 on topic 854 back rest project
Time to create page: 0.061 seconds
