Kohler parts questions
14 Oct 2015 16:24 - 14 Oct 2015 21:32 #1
Kohler parts questions was created by Geno
I need some info from the experts.
I have to place an opening order with Kohler to send along with the Dealer paperwork and wondered what Kohler parts do you guys use the most? It can be either because you like them best, or if it is a have to situation because that's all that's available.
I'll start a partial list here of what I know of and add to it later - If these items below can be bought at a better price in another good quality brand please let me know. Thanks all.
Points
Point cover gaskets
Camshaft cover gaskets
Oil pan gaskets
Head gaskets
Points
Point cover gaskets
Oil pan gaskets
Head gaskets
Last edit: 14 Oct 2015 21:32 by Geno.
- Thank you received: 137
14 Oct 2015 21:30 #2
Replied by Trouty56 on topic Kohler parts questions
Head gaskets
Carb kits (aftermarket probably cheaper)
Carb mounting gaskets
The following user(s) said Thank You: Geno, AJ WH Ranger
14 Oct 2015 21:32 #3
Replied by Geno on topic Kohler parts questions
Can the carb mount gaskets be found anywhere else Bob? They're pretty expensive through Kohler.
15 Oct 2015 20:40 #4
Like a JD dealer probably has them...maybe ebay....didn't know if Kohler charged a lot or not..Geno wrote: Can the carb mount gaskets be found anywhere else Bob? They're pretty expensive through Kohler.
15 Oct 2015 21:42 #5
If I remember right they may have been around $6.00.
16 Oct 2015 06:33 #6
Replied by GT 14 on topic Kohler parts questions
Air and oil filters
16 Oct 2015 12:07 #7
Will take a look at air, but I don't think I have a Kohler engine in the shop with an oil filter.
- Thank you received: 51
27 Oct 2015 21:01 #8
by JustinW.73
1973 Automatic 14
Replied by JustinW.73 on topic Kohler parts questions
How about starter/starter parts, internal parts (piston, rod, rings, etc.) You could probably get if you want coils, wires, points, stater. I'll see if I can think of anything else.
1973 Automatic 14
