- Thank you received: 0
Balance gears (?)
- kudzu
- Junior Member
- Thank you received: 137
Heck...I've even broken them out with a cold chisel.... Did that to a 16hp about 5 years ago on a 160....still ran as smooth as before....the guy that bought it still has it.
- Thank you received: 116
Trouty56 wrote: If you took them out leave them out.....without the tool to replace them they will shake the engine apart. Any time I open an engine I remove them before they remove themselves....
I agree with Bob, take them out and leave them out, you'll never know they were gone. Sometimes less equals more!
- kudzu
- Junior Member
- kudzu
- Junior Member
- kudzu
- Junior Member
- kudzu
- Junior Member
All engines are balanced to a point or they wouldn't last very long. As far as precision balancing goes, there are people who balance for longevity, some do it for performance, and some do it out of need. If you do balance it will always give you longevity, performance, an eliminate vibration period. The need comes in at higher RPM. Basically, too much weight on the end of something unbalanced at too high an RPM will always create more shear force and something will break. That will mean a lot of fancy parts, time, and effort down the tubes. I think the reason manufacturers don't precision balance is because if they did, with proper maintenance, an engine would last too long...
I tried to get this as simple as possible and hope I didn't get anything wrong in the breakdown.
