ONAN ID - WHS Forum
ONAN ID
03 May 2021 14:47 #1 by nappypappy
ONAN ID was created by nappypappy
Well been using the 93 520 h and i notice its not charging the battery ,so i think it may need a voltage regulator...simple enough.......wrong cant make out anything on the id on the engine....so what should i do in that case?>( :wrain :bacon0
03 May 2021 18:28 #2 by Geno
Replied by Geno on topic ONAN ID
Charging goes through the very problematic fuse block. Check the fuse and block first, then the 9 pin Molex connector between the battery and rear of engine next. That's where 90% of charging problems go back to.
03 May 2021 19:18 #3 by nappypappy
Replied by nappypappy on topic ONAN ID
Geno wrote: Charging goes through the very problematic fuse block. Check the fuse and block first, then the 9 pin Molex connector between the battery and rear of engine next. That's where 90% of charging problems go back to.
ok will check that and at the Molex on the outside of it somebody spliced the red wire to a white wire.....:bacon0
06 May 2021 16:32 #4 by nappypappy
Did look at the Molex and can tell why the wire is out side of it ...looks like there was a short since its got a little black in there.......so the splice makes sense or at least to me for now............:smile2 :smile2 :bacon0
06 May 2021 18:31 #5 by Geno
They get hot at the connection over time, the connector doesn't handle the amperage going through it and when the connection gets bad they heat up and cause what you're seeing. There are 2 connections that are most problematic at that connector, I can't remember the other wire colors though...
Time to create page: 0.064 seconds
