- Thank you received: 3
Starting Fluid - 520H Onan
- GoBucks
- Junior Member
GoBucks wrote: Should the choke close completely?
520H choke
Whatever that is above no one can see it without logging into Google and I have no idea what my login is it's been so long lol. If you have a pic on your computer just drag it into the post and the forum will take care of it automatically.
You should be able to close it completely, I wonder if the cable has enough throw to do it before it hits the sheath. A pic would be nice.
- GoBucks
- Junior Member
- GoBucks
- Junior Member
- GoBucks
- Junior Member
