- Thank you received: 2
Tiller mule drive? Or what?
- DennisThornton
- User is blocked
09 Aug 2015 12:54 #1
by DennisThornton
Tiller mule drive? Or what? was created by DennisThornton
I bought this for the snow plow welded to it. PO said the snow blade was attached and used as is but it's still a mystery to me...
Hoping someone could explain it to me!
Thanks
Dennis Thornton
Thanks
Dennis Thornton
- Thank you received: 323
09 Aug 2015 14:51 #2
Replied by nappypappy on topic Tiller mule drive? Or what?
I do hope somebody answers your question.....I aint no help with that...DennisThornton wrote: I bought this for the snow plow welded to it. PO said the snow blade was attached and used as is but it's still a mystery to me...
Thanks
Dennis Thornton
- DennisThornton
- User is blocked
09 Aug 2015 15:23 #3
by DennisThornton
Replied by DennisThornton on topic Tiller mule drive? Or what?
Didn't understand it when I saw it on Craig's List but felt sure I would when I saw it. Now I own it and still don't know what it is!
Do note the A frame for the blade sitting on the ground and of course the blade is off camera to the right. You can just catch the left spring in the upper right corner. A short angle iron was welded across the plow frame hence the dark weld areas. But the angled idler? The pivoting brackets with short pipes towards the front? With the blade where it would be used, what would the short pipes hook to? And what would the hangers on the rear of those brackets fit? The flat and v pulleys towards the rear? There are so many mysteries that I'm completely baffled...
The PO said it came off a Wheel Horse and the dozer blade is certainly a WH but I suppose the assembly on the back could be off something else? And maybe it did NOT come off a WH? Maybe someone added a WH dozer frame to whatever tractor they had? Several red tractors out there!
Still very confused...
09 Aug 2015 17:06 - 09 Aug 2015 17:07 #4
Its a mystery for sure....course you could have a rare part.......and I still aint any help...
Last edit: 09 Aug 2015 17:07 by nappypappy.
09 Aug 2015 17:10 #5
Replied by Geno on topic Tiller mule drive? Or what?
I've seen Cub attachments that looked similar but I don't know enough about them to know either.
- Thank you received: 116
09 Aug 2015 18:53 #6
Replied by M Bailey on topic Tiller mule drive? Or what?
? Never seen anything like that Dennis. Gotta love these previous owners
- DennisThornton
- User is blocked
09 Aug 2015 19:20 #7
by DennisThornton
You know, the assembly may not have come off a WH... Pretty sure the fellow said he saw it work, but whether he could tell a Wheel Horse from anything else I don't know.
Dennis
Dennis
09 Aug 2015 19:27 #8
It may have been on a Wheel Horse. I've seen all kinds of things on these old Horses.
09 Aug 2015 20:35 #9
Dennis after careful study, that looks like a short frame Wheel Horse blade that has been grafted to whatever the rest of that is. Guessing it's some sort of accessory drive.
- DennisThornton
- User is blocked
10 Aug 2015 00:55 #10
by DennisThornton
I think you are right on both counts, but the problem of "whatever the rest of that is" persists.
Time to create page: 0.207 seconds
