- Thank you received: 129
520H Rear Axle Oil Seals
- Kurt-NEPA
- Thank you received: 116
- Thank you received: 137
- Kurt-NEPA
- Thank you received: 57
if i know what is behind it wont be damaged i will
get small sheet metal screws that are long or some better drywall screws even work well
drill 2 or 3 holes in seal equally spaced around it
grind the point off the screw
start putting the screws in the drilled holes
as they bottom out go just half turn more on each
go back and forth on the screws and you will jack out the seal. bingo........
jm46322 wrote: i have removed many seals with small sheet metal screws.
I like that idea!
- Kurt-NEPA
- Kurt-NEPA
jm, I like the screw approach. I think I will try it. Worst case is that I will pull the axles and punch it out from the other side. I really don't want to do that.
Thanks.
