What i havent been doing 85 416-8 - WHS Forum
18 Mar 2015 16:40 #1 by nappypappy
What i havent been doing 85 416-8 was created by nappypappy
Well I wasn't sure where to put this question so here it is.
I need to replace muffler but the screws on the block are allen or are pretty rusty and no allen I have will turn them.
So what should I do next heat them up or what?
18 Mar 2015 18:04 #2 by M Bailey
Replied by M Bailey on topic What i havent been doing 85 416-8
Pappy are you going to replace it with another factory muffler or a stack? With the stack you could just cut the heads off the bolts and use the pipe threads in the cylinder casting. Otherwise heat, penetrating oil, cussing, drilling and tapping are required.
18 Mar 2015 19:12 #3 by Kyblue
Replied by Kyblue on topic What i havent been doing 85 416-8
M Bailey wrote: Pappy are you going to replace it with another factory muffler or a stack? With the stack you could just cut the heads off the bolts and use the pipe threads in the cylinder casting. Otherwise heat, penetrating oil, cussing, drilling and tapping are required.
You might try a ratchet with the right sized Allen head socket on a impact gun. Soak with wd40 or whatever you like for a few days first...heating the block in that area will help too
18 Mar 2015 19:39 #4 by Geno
Replied by Geno on topic What i havent been doing 85 416-8
The only thing you left out Major is more cussing. :rolling
If you want to try something easy and hope for the best Nappy you can run it till it's hot and try a good pair of vice grips. Try not to twist off the head so you don't have to go through the drilling, cussing, tapping and more cussing part. :rolling2
I have an extractor that will fit over those. The impact usually pops them right out, most of the time anyway. Heat is one key, and like Blue said, the hammer action is the other. :)
The following user(s) said Thank You: Kyblue
18 Mar 2015 19:53 #5 by Scott
Replied by Scott on topic What i havent been doing 85 416-8
:goodpost I agree with Geno and Blue on this.
18 Mar 2015 20:11 #6 by nappypappy
Replied by nappypappy on topic What i havent been doing 85 416-8
Scott wrote: :goodpost I agree with Geno and Blue on this.
ok thanks everybody..not sure which way I will go yet but they have to come out....I like the stack the best....I have plenty of allens both standard and metric but
none are a tight fit...
18 Mar 2015 20:18 #7 by Scott
put the tightest allen wrench in the bolt and use a good set of vice grips over the head and use both to try and crack it loose. A impact really helps in these situation.
19 Mar 2015 05:54 #8 by GT 14
Replied by GT 14 on topic What i havent been doing 85 416-8
Header bolts are always a treat.
21 Mar 2015 08:38 #9 by M Bailey
Any luck with those bolts yet Pappy? Here's my 416-8 with a Ford 8N muffler. Part number FD1110
21 Mar 2015 10:04 #10 by nappypappy
M Bailey wrote: Any luck with those bolts yet Pappy? Here's my 416-8 with a Ford 8N muffler. Part number FD1110
no luck yet....been putting oil on them........I like that stack thanks.
Time to create page: 0.085 seconds
