New Template
05 Jan 2017 08:47 #1
New Template was created by Geno
I'm using this topic for testing also. There's something slowing the post process, it takes too long once you press the submit button for the post to happen. It's been doing that for a little while and I think it's the interaction with another module.
So what are your thoughts so far? Is everything user friendly? Is there something else that needs work?
05 Jan 2017 08:47 #2
Replied by Geno on topic New Template
Test
05 Jan 2017 08:50 #3
Well the posting is lighting fast now.
It was a conflict with the calendar module at the bottom of the forum page. I removed the calendar from the bottom of the forum page before I started this topic because I though that may be the problem. The calendar is still in the main menu and on the front page.
- Thank you received: 73
05 Jan 2017 09:56 #4
Replied by motor12 on topic New Template
I like it, seems easy to get around.
05 Jan 2017 10:13 #5
Thanks Motor. If you see anything that could be improved on please let me know.
05 Jan 2017 11:10 #6
Replied by GT 14 on topic New Template
So far so good, will continue to browse.
05 Jan 2017 11:35 #7
Keep me advised GT.
- Thank you received: 323
05 Jan 2017 12:28 #8
The only improvements I can think of is in your shop and clearing out some more stuff you don't need..........
Replied by nappypappy on topic New Template
Geno wrote: Thanks Motor. If you see anything that could be improved on please let me know.
08 Jan 2017 14:44 #9
There was a problem with the text at the top of a section or new post overlapping, just got that worked out. I think that may be it. If anyone sees anything else let me know.
10 Jan 2017 13:27 #10
Everything seems to be working fine, still take awhile to submit a reply.
Time to create page: 0.078 seconds
