What's everybody doing?
27 Apr 2018 09:34 #371
I would check the points 1st, and make sure you're getting power to the coil and points. Call me if you want to.
- Thank you received: 323
27 Apr 2018 09:51 #372
ok will give you call in a few minutes.............thanks......................
Geno wrote: I would check the points 1st, and make sure you're getting power to the coil and points. Call me if you want to.
28 Apr 2018 11:48 #373
Getting ready to rebuild and put my new trued up holders in the lathe chuck after lunch today, it's time to make some stuff!
- Thank you received: 73
28 Apr 2018 14:47 #374
Your right, its time to make some stuff. I decided to gather up what parts I had for a Kohler K91 and put together a nice little motor. Spent most of the morning disassembling the block and wire brushing with mineral spirits to get rid of years of oil and baked on crud not to mention the old blue paint. Should have taken a before photo but forgot. here's the block and oil pan after some nice red paint.
28 Apr 2018 15:21 #375
It's Spring fever Motor lol, looking good.
30 Apr 2018 19:18 #376
Still in cleaning mode.
I have a wide path to the parts washer, there was a 4' shelving unit back there and the clean part of the work bench has been stacked with parts that needed to be put in the parts washer for years. The last of the parts to be put in the parts washer are disassembled and ready to go in tonight. There was another 4' shelving unit in front of the lawn ranger with the blue tarps on the seat. Both shelving units are back with the rest of the parts now. I've blasted, painted, cleaned and assembled a lot of rear hitches and a lot of other things. I'm finally getting some things done lol.
30 Apr 2018 20:11 #377
Lookin good.......................................................
01 May 2018 07:58 #378
Get er Done
01 May 2018 09:04 #379
I recognize some of those parts. Enough to keep you busy for a while. Looking forward to your next dealer buy out.
03 May 2018 13:11 #380
My back is wore out by 7pm or so from standing in 1 place too much, either the parts washer or the blaster. The next round is blasted, painting started, and the parts washer is filled up again. I think I may be starting to see an end in sight. I have a nice path to the parts washer and another work bench cleared.
